Angled trailer tongues
Postby WesGrimes » Tue Sep 15, 2009 10:59 pm
I have noticed looking through others designs that some of the trailer tongues are bent up to allow for attachment to a taller TV. Does anyone know where to get one of those bent tongues?
Thanks,
Wes
WesGrimes
Images: 31
drop hitch??
Postby laoutdoorsman » Tue Sep 15, 2009 11:46 pm
wouldnt it be just as easy to get a drawbar(ball mount) with a drop in it??
if not...fabricate it into the trailer build...unless trailer is already built??
mike breaux...its pronounced "bro".....
i think i should have taken notes along the way, because ive forgotten waaaay more than i remember...
laoutdoorsman
Images: 44
Postby madjack » Wed Sep 16, 2009 1:24 am
Wes, if you mean the drawbar(part with ball on it), you can find different heights at WalMart(usuallY) you can also go to any truck/trailer accessory store and find 'em...if you have a U-Haul Company Store, a tractor Supply...etc they should have several different choices as well...if you actually meant the tongue, that has to be built into the frame design...not an off the shelf part ;)
Postby George G. » Wed Sep 16, 2009 3:12 am
The way I read his post. He's most likely talking about the way the KIT's tongue bends upward. :thinking:
George G.
Postby Steve_Cox » Wed Sep 16, 2009 6:19 am
Harbor Freight sells a hydraulic pipe bender, for bending those classic round tubular tongues 8)
Steve_Cox
Images: 196
Postby doug hodder » Wed Sep 16, 2009 9:21 am
I haven't seen a manufactured tongue kit or frame for sale with an upward curve in it, but I've made my own and stacked some 2x3 rec. tube on the coupler end to get more height. I'd imagine that you could have one rolled for you, but like previously mentioned, there are less expensive methods to achieve what you want. Doug
