I'm using 3/4 ply for my sides
what is the best to use to fix the sides to the frame?
are decking screws enough as I'm using 2' * 3' framing pine under my floor or should I use something meatier like a batton screw
marcel
type82e wrote:I'm using 2' * 3' framing pine
marcel
type82e wrote:batton screws are what you use to screw down battons on a wood frame roof say under currugated iron
they have a hex drive theyre probably 5 mm thick twice as thick as a decking screw maybe its an australian term?
marcel
