Hi Susan, Q...Susan Q...?
There are some (too many to see in one lifetime) really neat places here in the USA.
My son and I went in 08, then my wife and daughter and I went to the same places in 09, and I saw many things that we didn't see the first time.
The wagon is an authentic "chuck wagon" from a Western ranch that was used to feed the wranglers during round up and other "away from the main ranch" chores.
It is in need of a spruce up...
Tony made a good point, and one I should have mentioned.
When applying varnish, if the surface looks pretty smooth, but there are still a few places that look dimpled, it needs another coat.
When you can look over the entire surface at a steep angle with a strong light, and there are no dimples (low spots where open grain is still drawing the varnish in) you're close.
Give it a very careful final sanding (the results will make or break the appearance of the finish) then with the utmost care, apply the final coat.
Rob
