alternates?
alternates?
Postby SpringerNC » Mon Sep 28, 2009 12:09 pm
I have worked for my father in law here and there since marrying his daughter in 2000, he just so happens to be a cabinet shop owner and his shop is 50 yards from my house....SO the question, I have a supply of off colors of melamine, 4x8's I could use. IF you are covering the floor with sealant, is there any reason to not use alternate woods? Has anyone ever used different materials so save some cash?
I have a 4x8 trailer just itching to go, I am just hesitant to start.......getting close though...
thanks for the help
SpringerNC
Images: 6
Postby Miriam C. » Mon Sep 28, 2009 4:04 pm
Are you wanting this for the floor. Should work fine for the top of the floor. Just seal the bottom and sides really well.
:thinking: Free Melamine? ? ? :twisted:
Postby cordes56 » Tue Sep 29, 2009 2:03 pm
I was also thinking of using a non-wood product for the floor. Why not.....less work of sealing, can be screwed to framing? I will follow this post also because I think you are on to something too!! Heck you could use plexiglas, lexan........... :thinking: Have to look into the material you are suggesting. Right now, I just completed my trailer, will paint, then start the actual build this fall.
cordes56
Postby SpringerNC » Tue Sep 29, 2009 4:13 pm
originally I too was all about some lexan for a roof, but just so brittle, not sure that would be a good call for a bend. flat roof and I would go lexan for sure...
SpringerNC
Images: 6
Re: alternates?
Postby aggie79 » Tue Sep 29, 2009 4:20 pm
SpringerNC wrote:I have worked for my father in law here and there since marrying his daughter in 2000, he just so happens to be a cabinet shop owner and his shop is 50 yards from my house....SO the question, I have a supply of off colors of melamine, 4x8's I could use. IF you are covering the floor with sealant, is there any reason to not use alternate woods? Has anyone ever used different materials so save some cash?
thanks for the help
Most of the melamine that I have seen has a particle board core which is very vulnerable to moisture. Of course, if you can seal it well, as you mentioned it may work. Another thing to consider is that it is nowhere near as strong as plywood, so you'll probably need to consider this on your frame design.
Postby David S » Wed Sep 30, 2009 12:34 pm
I agee with all the coments about melamine with this addition THAT STUFFS HEAVY :? It's the main reason I bought my fork lift.I weighed a sheet one time just for kicks, 99lbs. Won't hold screws to well either.
My 2 cents, you get what you pay for.
David S
Images: 53
Postby aggie79 » Wed Sep 30, 2009 1:00 pm
David S wrote:I agee with all the coments about melamine with this addition THAT STUFFS HEAVY :? It's the main reason I bought my fork lift.I weighed a sheet one time just for kicks, 99lbs. Won't hold screws to well either.
+1 on the heavy comment.
Postby bobhenry » Wed Sep 30, 2009 1:16 pm
SpringerNC wrote:originally I too was all about some lexan for a roof, but just so brittle, not sure that would be a good call for a bend. flat roof and I would go lexan for sure...
3/16 Lexan roof just bend it slowly over several hot days
Was it worth the trouble ????
Hell yes
Postby wannabefree » Sat Oct 03, 2009 2:51 pm
I have so much time in the Paskett Case it didn't make sense to try to save $ on material. I started out trying to save $, but soon realized that the time investment was far greater than the material cost. If you want to save $, buy a ready-made. You won't reget it. IMO, of course.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
