I am looking at one called Camoclad
The stuff ain't cheap though...
Opinions? Thoughts?
(No, I am not affiliated with any related products or services...)
madjack wrote:Wes, I had checked into them when I decided to build the Gatorflage Tear but found them to be cost prohibitive...first you havvta have a finished exterior in either aluminum or epoxy and then the hi-cost wraps...which don't last forever...I ended up using camo cloth embeded in epoxy which worked very well.........
kennyrayandersen wrote:The UV can be a problem, especially with a lot of inks. Fabrics use dyes, but they will fade as well. I’m guessing you could slow the whole fading process by:
1) Using a UV coat on the outside
2) Parking it in the garage out of the sun
