Sealing sides with varnish?
Postby Ron51 » Thu Oct 08, 2009 9:32 am
I am close to staining the sides and doors before I start to assemble the TD. I was thinking of using Cabot oil base stain and Cabot spar varnish interior/exterior & marine durability ultimate UV protection. Would this give the 3/4 inch plywood sides and doors a protective durable finish?
Thanks Ron and Margaret
Ron51
Postby Arne » Thu Oct 08, 2009 10:17 am
exterior; temporarily.... plan on redoing ever year or two. especially if stored outside.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby madjack » Thu Oct 08, 2009 11:42 am
Arne wrote:exterior; temporarily.... plan on redoing ever year or two. especially if stored outside.
...yep +1...plan on between 3 to 6 coats to begin with, with sanding/additional coats in the future as needed...
Postby wannabefree » Thu Oct 08, 2009 8:25 pm
What they said. I find Cabot is a good product and the right price. That said, I hate varnish because of the drying time (mostly) and find it too yellow for my taste. I used Emtek over epoxy. If you're interested, search the threads for Emtek.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby Ron51 » Wed Oct 14, 2009 12:47 pm
Thanks for the replies. I plan on storing it either in the garage or under roof on the side of our storage shed. The next question is will glue stick to the varnish when we finally start to assemble the sides to the bare floor and roof spars?
Ron and Margaret
Ron51
Postby Ageless » Wed Oct 14, 2009 12:52 pm
That wouldn't be my choice. Leave interior surfaces bare until assembled; then apply finish
Ageless
Postby Nic » Mon Nov 16, 2009 12:23 am
Let me tell ya. THAT'S the TRUTH! If you don't re treat it every year it will go to hell.
Im not lazy. I just hang out a lot.
Nic
Images: 169
Postby Scooter » Wed Nov 18, 2009 10:37 am
I sealed with varnish, and yes it'll have to be redone before long, esp on oak which tends to turn ugly gray-black within the grain.
However, a few of these strategic "shortcuts" enabled me to actually finish the project rather than stalling out for an extended period...which I tend to do with big projects. :oops:
The RoadCamper the old teardrop
Scooter
Images: 69
Postby Nic » Mon Nov 23, 2009 11:30 pm
HAHAHA! That sounds like me and what I'm dealing with now. :roll:
Nic
Images: 169
Postby madjack » Tue Nov 24, 2009 7:35 am
Ron51 wrote:Thanks for the replies. I plan on storing it either in the garage or under roof on the side of our storage shed. The next question is will glue stick to the varnish when we finally start to assemble the sides to the bare floor and roof spars?
Ron and Margaret
...wood glues such as TiteBond will not...urethane based construction adhesives such a PLPremium will but not as good...this is a pretty good spot for such as GorillaGlue....as always, read and follow manufacturers directions...........
Postby Steve_Cox » Tue Nov 24, 2009 7:55 am
Back to the first question. The varnish will look great with enough coats. But the points of failure will be at the plywood endgrain if moisture, even from humidity gets to it. I'd seal the edges of all plywood with several coats of epoxy.
Steve_Cox
Images: 196
Edges of Ply
Postby Chris D » Tue Nov 24, 2009 8:02 am
Hey Steve,
When ya say epoxy, would that be thickened or just thin epoxy?
by thickened I mean mix up as fairing putty.
Chris D
Chris D
Re: Edges of Ply
Postby Steve_Cox » Tue Nov 24, 2009 8:58 am
Chris D wrote:Hey Steve,
Chris D
For plywood endgrain coating I use regular West Epoxy not thickened. It takes about 3 coats to fill in completely. I use thickened epoxy, same brand for gluing. Often using wood flour as the thickening agent. I save sander dust from my orbital sander, and have dust or "flour" from several different types of wood for that use. I've also used CPES as well, it goes on easy and will waterproof plywood with 3 coats. I epoxy glue my trim on trailer projects mostly to make it all waterproof. Often it just gets clamped in place til the epoxy cures. Screw holes are another place that seem to absorb moisture. After years hanging around boat yards, you get to see all kinds of wood damage in different stages, from varnish just starting to fail to hardwoods that have turned to pulp and can be removed by the handful. Dry-rot is just rot that has temporarily dried out. :lol:
Steve_Cox
Images: 196
Epoxy
Postby Chris D » Tue Nov 24, 2009 9:07 am
Ok Steve,
Thanks. I read someplace you can use epoxy unthickened as a penatrating sealer, like cpes. Is this true? And next Question. If I plan on using spar varnish as a uv finish can I first paint the sides with unthickened epoxy sand and then finish with spar.
Chris D
Chris D
