I have no machinery or tools to do so as of yet. The diameter is only 12 to 25 millimeters so nothing real heavy. What tools can be used?
Id like to attempt to make a nice roof rack for our tear this why the question.
Classic Finn
PaulC wrote:G'Day Heikki![]()
You'll need some sort of insert, maybe a coil type spring to fit inside the pipe and a gas torch of some sort. Fit the spring in the area you want to bend, apply enough heat to soften the ally and bend it to your required shape. Softening the aluminium is also called annealing. It's easy, really.
Cheers
Paul
PS Plumbers used to use a flexible, stainless steel thingy to fit inside copper tubing when they needed to bend it BUT that was when I was a lad
TerryLawson wrote:you all are doing it all wrong!!!!! Try this
