Hi Matt , I am in the process of skinning my TD with FRP. I finished the top & front this weekend. I will be doing the walls & hatch this week. I liked the texture too, but I have since found out thru the board that it has to be painted to protect from UV
So I will be painting it soon. I will post some pics when I get the skin on. I used Henry 444 adhesive on it. The bend on the front of the tear was a pain because I had a jont fall there. My TD is 12 ft BTW. I used the H channel for that joint & will be using it on the sides as well. Good luck.
