Small question - Screwing in tail lights
Postby Alfred » Sun Oct 25, 2009 8:14 am
Hey Gang,
I am attaching these recessed tail lights to 1/2" plywood. There are three holes for screws on the flange of each light (see pictures). Should I just screw exterior screws into the wood, or should I drill holes and use nuts/bolts?
Thanks,
AL in Asheville :thumbsup:
Alfred
Images: 368
Postby aggie79 » Sun Oct 25, 2009 8:21 am
Al,
Your teardrop is really starting to come together very nice. I had the same question too. My options are: add another thickness of plywood as blocking and use wood screws (actually probably sheet metal screws) or bolts and nylock nuts. I'm also wondering if I use the bolt option, do I need some sort of access panel on the interior.
Postby Juneaudave » Sun Oct 25, 2009 9:28 am
Al...I don't think there isn't a wrong answer here...either is ok. If it were me, I would probably just use round head stainless steel screws as I can't see a need for a bolt for a taillight with that type of mounting flange. Whether you use bolts or screws, before you mount the lights "permanent", be sure to seal the taillight holes in the ply with something and use a dab of 3M 5200 sealent or similar for the screw or bolt holes so you don't give water a chance to get in.
Juneaudave
Images: 380
Postby Arne » Sun Oct 25, 2009 10:42 am
some type of sealant and screws... there is very little stress to deal with.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Another Option
Postby dh » Tue Oct 27, 2009 5:28 pm
another option, I've never used them for this application, but I'm sure it would work.
Lowes and Home Depot both sell threaded inserts for wood. Drill a hole, tap them in (they have claws to hold them in) and you have a nice durable metal insert for your screws.
dh
Re: Another Option
Postby Alfred » Wed Oct 28, 2009 6:30 am
dh wrote:another option, I've never used them for this application, but I'm sure it would work.
Yes, These are nice, we used them for the license tag!
Al in Asheville :thumbsup:
Alfred
Images: 368
Postby cokebottle10 » Thu Oct 29, 2009 8:23 am
Hey Al,
I would use #8 x 1 SS screws. Predrill the holes with a very small bit. The lights are mounted in 1/2 ply and the screws should hold them just fine. Please keep in mind the LED lights will look different if they are not aligned the same. Also if those LED lights stop working you will have to replace them. You can not fix them. I would get one more just in case that happened.
Thanks,
David.
cokebottle10
Postby doug hodder » Thu Oct 29, 2009 8:36 am
If you do install them using a nut and bolt technique as opposed to a screw, make sure you have access behind it to remove it, or use a T nut so that the light can be removed after the project is finished. I'd do screws and a dab of sealant behind the flange. Doug
