Hatch Framing Conundrum
I have completed my galley hatch framing, but am second guessing my design, and would appreciate comments before I skin the framing.
As it is now, the hatching framing has four continuous ribs - two on the sides and two interior. The depth of the ribs is 1 1/2". The outer ribs are made from two thicknesses of 3/4" plywood. The interior ribs are single thickness 3/4" plywood. The header spar for the galley hinge is made from two 1x2 poplar boards. The other spars are single 1x2 poplar boards, and are spaced at approximately 12" on center. The spars are pocket-screwed and glued to the ribs, and I've added gussets to many of the spar/rib butt joints.
Off the teardrop, the assembly is quite stout and does not flex or rack much. I plan to skin both sides of the hatch with 1/8" baltic birch plywood (with aluminum exterior sheeting.) That said, I've had some concerns that the framing won't be strong enough for the tight curve of the profile at the back of the teardrop.
My questions, to the long-winded set-up, are:
1. Do you think the 1 1/2" depth of the framing is sufficient?
2. Is there a modification I should make to the framing to increase its strength?
3. Or should I start over on the hatch framing?"
Thanks, Tom
Thanks, Tom
