Epifanes Sealer
Epifanes Sealer
Postby shortgmanp » Sun Nov 01, 2009 7:27 am
I am planning on using Epifanes rapid coat varnish. Anyone familiar with this. I Have read only good things about it. Thanks Greg
I am a workaholic that loves a good challenge. It will also give my dad and me a good project to work on together. I plan on putting several miles on this teardrop, so I want to build it right.
shortgmanp
Images: 99
Postby doug hodder » Sun Nov 01, 2009 8:49 am
Epifanes is highly respected in the boat building community and a lot of the top restored boats use it. Doug
Postby schaney » Sun Nov 01, 2009 9:03 am
I used it on my kayak
What I found was it goes on thin and with the fast dry time leaves brush marks. I did 6-7 coats, then sanded it out, I wasn't getting the depth I wanted. So I switch back to their Clear Varnish, did an additional 4 coats, came up great. It's about 5 yrs old now and still looks great.
Scott
Camping the "Compact Way"
schaney
Images: 262
Brush marks
Postby shortgmanp » Sun Nov 01, 2009 12:50 pm
Well if it leaves brush marks it may not be for me. I might just have to go with the clear.
shortgmanp
Images: 99
Postby wannabefree » Sun Nov 01, 2009 5:18 pm
If you don't want brush marks, don't use a brush :lol:
Seriously, I have not found a finish that, when put on with a brush, does not leave brush marks. If anyone has one, please let me know.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby schaney » Mon Nov 02, 2009 9:06 am
Actually with Epifanes Clear Varnish I was able to get a brush mark free finish. After a light 2000 grit sanding and polish, it had a nice mirror finish. I'm also having pretty good luck getting a brush mark free finish with Target Coatings EM2000. The trick with it is temp, applying it around 60 degree extends the dry time and allows it to level out. At about 70 degrees I get brush marks every time.
Scott
schaney
Images: 262
Postby Sawyer » Thu Nov 05, 2009 1:01 am
Fine Woodworking did a outdoor finish torture test a few months back, and if I remember correctly, Epifanes products stood out head and shoulders above all other tested finishes. It was a pretty interesting and informative article... Unless I hear of something better, I'll definitely be using it on my next TD! I used Varithane Spar on my current TD, and have been very happy with the results, except it gets slightly soft and hazy in an extended downpour (thank you '09 Dam Gathering).
Keep us updated with how it goes with the Epifanes...
"Those who would give up a little freedom to get a little security shall soon have neither" - Benjamin Franklin
Sawyer
Images: 36
