Does anyone see any issues I would run into if I were to use this trailer? I suspect that I'll need to cut the sides off, but otherwise I don't see any issues with using it. Can anyone with a more informed eye see any issues?
Thanks for the help!
Ageless wrote:Should work without the metal sides but you may need to change the spring rating; 2 1/2 tons is a bit much
ChromeShine wrote:Ageless wrote:Should work without the metal sides but you may need to change the spring rating; 2 1/2 tons is a bit much
First, thanks for the info!
Is there any harm in leaving it that way? What are the implications? I don't know anything about this kind of stuff so I'm completely in the dark.
madjack wrote:...remove the excess steel, dump the old floor and move the axle rearward about a foot and you should have a good base for a TD....
ChromeShine wrote:madjack wrote:...remove the excess steel, dump the old floor and move the axle rearward about a foot and you should have a good base for a TD....
As with the spring question, why wouldn't I be able to leave the axle where it is? Is there some structural reason?
Sorry for all the questions, just trying to understand so I do the right things.
Thanks!
Wolfgang92025 wrote:ChromeShine wrote:madjack wrote:...remove the excess steel, dump the old floor and move the axle rearward about a foot and you should have a good base for a TD....
Thanks!
Unless you plan on putting everything in the front of the trailer, your tongue weight is likely to be to low. Moving the axle back solves that problem.
http://www.angib.pwp.blueyonder.co.uk/teardrop/tear81.htm
Check the link for more info...........
wolfgang
xzerokidx wrote:Also adding your location might help to find a member/welder here to lend a hand.
