Alternative external trim ideas
Postby David Beckett » Wed May 11, 2005 7:52 pm
I installed 3/4" AL angle trim on my tear and I'm not happy with certain parts of it. :(
I roamed Lowes aisles exploring other alternatives. The one I am thinking about is to use a rubber water hose. I'd slit it lengthwise and glue and screw it around the edges.
Any thoughts on this idea?
Any other trim ideas?
:thinking:
Thanks,
David Beckett
Postby SteveH » Wed May 11, 2005 9:35 pm
Steve Wolverton did a simular thing with I believe it was garage door rubber seal.
SteveH
SteveH
Images: 42
Postby Scooter » Thu May 12, 2005 9:43 am
Those are great ideas. I'm getting 99% of my materials at Lowe's and HD and would love to see more ideas of alternative uses of their products on teardrops.
The RoadCamper the old teardrop
Scooter
Images: 69
Postby Guest » Thu May 12, 2005 10:00 am
I'm doing a full woody now and I'll be building a laminated profile piece probably out of white ash.
In my opinion, a full woody needs this piece... 70% for looks, 30% for bangability.
Guest
Postby SteveH » Thu May 12, 2005 11:21 am
bangability
That's a new one for me, but hey, I like it! Somehow another picture comes to mind....... :roll:
SteveH
SteveH
Images: 42
alternative trim
Postby David Beckett » Thu May 12, 2005 4:52 pm
Scooter,
I may be wierd but one of my great loves in building things is to roam a store looking for something for a purpose for which it was not produced. I recall a psych class where "functional habituation" is that a hammer can only be used as a hammer. Creative people look at a hammer and think of lots of other ways to use it.
Thanks for the encouragement. :D
David Beckett
aluminum carpet edging
Postby Q » Thu May 12, 2005 7:56 pm
I used quite a bit of aluminum carpet edging for trim. It comes in long lengths, it's cheap, has predrilled holes, and looks good.
Q
Q
Re: alternative trim
Postby Geron » Fri May 13, 2005 4:54 am
David Beckett wrote:Scooter,
I do the same thing. Salesperson walks up and asks, "May I help you." "Nope, just looking for ideas. Not a clue what I want till I see it!!"
Geron
Geron
Images: 173
Re: aluminum carpet edging
Postby mikeschn » Fri May 13, 2005 5:11 am
Q wrote:I used quite a bit of aluminum carpet edging for trim. It comes in long lengths, it's cheap, has predrilled holes, and looks good.
Q
The carpet trim is a good idea. I'll have to go and look at it!!! :thinking:
Postby IraRat » Fri May 13, 2005 7:04 am
I was thinking about carpet trim from the very beginning, but does that stuff hold up under the elements? Also, to bend around our curves?
--Ira
IraRat
Forum Storyteller
Postby mikeschn » Fri May 13, 2005 7:08 am
IraRat wrote:I was thinking about carpet trim from the very beginning, but does that stuff hold up under the elements? Also, to bend around our curves?
All very good questions... That's why I want to go and look at it... :eyebrows:
Postby Scooter » Fri May 13, 2005 8:19 am
If we stuck to products intended purpose only, there'd probably be no such thing as homebuilt teardrops! :cry:
Scooter
Images: 69
carpet edging
Postby Q » Fri May 13, 2005 1:10 pm
The aluminum carpet edging holds up just fine to the elements. It also bends easily around curves, being a pretty much flat profile. I used it for almost all the trim on my tear. I used the plain aluminum stuff but if you want to get fancy, it comes in gold anodized.
Q
Q
Re: carpet edging
Postby IraRat » Fri May 13, 2005 1:31 pm
Q wrote: it comes in gold anodized.
Q
You said the magic words.....
--Ira
IraRat
Forum Storyteller
alternative trim
Postby David Beckett » Sat May 14, 2005 12:54 am
Q,
So this is not the angle carpet edging for stairs, right? You're talking about the edging for carpet to vinyl transitions?
David Beckett
