ajricher wrote:Having had mine apart once you can re-square the edges of the moving blade on a whetstone without too much trouble. I've done it more than once. the anvil (the bits that don't move) I have not done but I doubt they will show the wear that the moving shear does.
Alan
I use a hand held jig saw to do a lot of metal cutting. I've cut lots of 1/4" steel (slow for sure but I "get er done"). Cutting the .032 or .040 aluminum for the skins would be a piece of cake.
ajricher wrote:I must confess that I've used a jigsaw extensively for cutting heavy sheet/light plate steel. All of the caveats above (good blades and such) I wholeheartedly agree with save the cooling -Ii've never felt the need and not had a problem.
I do think that cutting the .032 might be a real problem with a jigsaw, though, unless you can find a really fine blade. Either that or the blade speed needs to be high and the feed slower to keep from jamming the material and shearing teeth.
Do shield the shoe of the saw when cutting bare aluminum or you'll leave "tracks" on the surface - scratches. I usually stone/file off the sharp edges on the shoe of the saw, then cover it with a few layers of heavy electrical tape or the like to give a soft surface to the shoe. This way it doesn't scratch....
Alan
