Page 1 of 1
Should I use the free windows?
PostPosted: Fri Nov 27, 2009 11:29 am
by BK One
A good friend gave me these unused shed windows. They're made to frame into 1 1/2" framing.
Pros: They're free. They fit in my door. They've never been used. They're free.
Cons: They're a little heavy. My doors are only 1 1/8" thick. I can trim them out. They're white. I really need black or mill finish.
What would you do?
PostPosted: Fri Nov 27, 2009 11:57 am
by dovaka
i would probably use them and trim them out
PostPosted: Fri Nov 27, 2009 12:02 pm
by Ageless
Most RV windows disassemble easy. Either use a wire wheel to remove the white or shoot them black.
PostPosted: Fri Nov 27, 2009 12:05 pm
by cokebottle10
You my want to look at what happers when the windows are open and you open the door. If they crank out then they may hit the side of the trailer when you open the door.
Thanks,
David.
PostPosted: Fri Nov 27, 2009 1:04 pm
by Arne
That isn't really a problem... I ran a decrative rope from an eyelet in the door to one in the door frame.. they only open to 90 degrees...
given that windows cost at least $40, no doubt I'd paint them and use them.... no doubt at all.... but I repeat myself....
PostPosted: Fri Nov 27, 2009 5:27 pm
by b.bodemer
If you are worried about the windows being opened and hitting the side of the trailer just add a door stop.
Free is good!!!!
Barb
PostPosted: Fri Nov 27, 2009 5:56 pm
by RICHARD FURROW
WONDERING DO THEY HAVE TO HAVE DOT APPROVED GLASS?ANYBODY KNOW,LOOKS GREAT, HOPE YOU CAN AS FREE MAKES THEM LOK EVEN BETTER!
RICKY
PostPosted: Fri Nov 27, 2009 5:58 pm
by RogHodge
I’d use them- :thumbsup:
Better yet- I’ll give you my address- you send them to me- I WILL use them- and I’ll tell you how it turns out. :lol: :lol: :lol:
Free is a really good price!
My vote is to use them.
If the glass is a concern then disassemble them and pop in some lexan or other safety glass.
Re: Should I use the free windows?
by Jst83
BK One wrote:Cons: They're a little heavy. My doors are only 1 1/8" thick. I can trim them out. They're white. I really need black or mill finish.
What would you do?
I'd say go for it you can always change out the doors later and put in different windows which is what I'm doing. For heavier doors go with piano hinges. I know where you can get some heavy duty ones real cheap like $5 off an old ambulance. I PM'd you
