An all 1x material frame is a bit daunting for a total novice with the radii and compound cuts and pocket screws and glueing.
I think the full sheet/sheets method is much more straight forward.
Find a few radii that make up the profile you like and simply cut it out.
When I built chubby I used 2 1/2 full sheets of 1/2" osb stood on end for each side.
I would have to check notes to give the exact radii but it was simply a long stinny board ripping and a nail at the pivot point and a hole drilled for a pencil to mark the cut line
Here is a 4x8 layout With refinements by Andrew
http://www.mikenchell.com/forums/viewtopic.php?p=180832&highlight=#180832
As Chubby is 5'6" tall and just under 10' long it took 3 different sheets The center sheet was narrowed to 43 inches so it would lap right on the door reinforcing post and the galley wall. The sheets were screwed and glued to the 1x4 underneath to join the two sheets
Here is the reinforcement at the door
In this framing side shot ....Notice I tied all 3 sheets together with the 1x4 bottom board running full length. The side sheets extend below the floor and are screwed and glued to the 2x4 ribbon at the edge of the frame so this 1x4 helps carry the weight of the wall to relieve the strain that would otherwise be on the fastners only
The 3/4 void is enough to wire the wall for electrical and I simply drilled 1/4 " holes thru the 1x4 where needed. These are hard to do with the outer sub skin on as the drill case get in the way a bit , so a little preplanning of these holes would make this step a bit simpler.
NOTE : try and group your electrical runs and make a mental note where they are, so should you brad nail on your inner skin you will not shoot fastners into your wiring !
After wiring fill with 3/4 blue foam board and skin the inside.
