Piano Door Hinges
Piano Door Hinges
Postby Jst83 » Wed Dec 16, 2009 11:00 am
I'm looking at piano door hinges on my build and was wondering what's a good open to support the door. I've found Stainless Steel local in 2" width which means 1" on each side. Is that wide enough?
Jst83
Images: 215
Postby madjack » Wed Dec 16, 2009 1:48 pm
...that is the size I used on our first build..worked great...don't forget to peen the end knuckles onit so the pin won't drop out, going down the road...
Postby Cliffmeister2000 » Wed Dec 16, 2009 1:53 pm
What madjack said!
I chose aluminum rather than steel. Easiser to avoid sharp edges.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby Arne » Wed Dec 16, 2009 2:32 pm
same thing I used... got at a marine store.... stainless.
I think they dimple the hinge so the pin can't move.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Jst83 » Wed Dec 16, 2009 4:03 pm
Arne wrote:same thing I used... got at a marine store.... stainless.
Ok so 2" is large enough, you say they dimple the pin so it can't move even if you cut a 6' down to size
Jst83
Images: 215
Postby Cliffmeister2000 » Wed Dec 16, 2009 4:25 pm
You might have to do your own dimpling, or make sure you hang the hinge with the factory dimple on top.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby tinksdad » Wed Dec 16, 2009 7:03 pm
Make sure the pin is stainless too. I didn't! The leaves were stainless, the pin is rusting!!!
tinksdad
Images: 155
Postby Jst83 » Wed Dec 16, 2009 7:15 pm
tinksdad wrote:Make sure the pin is stainless too. I didn't! The leaves were stainless, the pin is rusting!!!
How can you tell, Where's a good supplier for stainless if the ones I'm looking at don't have stainless pins?
Jst83
Images: 215
Postby tinksdad » Wed Dec 16, 2009 8:10 pm
:x Wish there was an easy answer. I still have the blister pack mine came in and the label said 100% stainless. Maybe it was just a REAL cheap grade of stainless.
tinksdad
Images: 155
Postby prohandyman » Mon Dec 28, 2009 9:19 am
Scott
I found my SS piano hinges that I used on the lodge at Fastenal! I assume the pin is SS - hasn't rusted.
Dan
prohandyman
Images: 785
Postby sid » Mon Dec 28, 2009 9:30 am
http://www.mcmaster.com/#door-hinges/=54mnhn
McMaster-Carr is where I got mine.
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
sid
Images: 194
Postby Jst83 » Mon Dec 28, 2009 10:37 am
prohandyman wrote:Scott
How funny I've been talking to the Fastenal guy that makes the deliveries here at the prison and he getting me a quote with discount on them.
How wide were the ones you used on the lodge? the widest I see in the catalog with predrilled holes was 2" I assume that's open flat
Sid love McMaster Carr got a few things for the first one from them very quick service.
Jst83
Images: 215
Postby prohandyman » Mon Dec 28, 2009 12:46 pm
Scott
Mine are 2" wide when open - 1" each side. Seem to be okay. My wood doors are fairly heavy. I just took one off to re-skin the inside and re-attached it. No problems with hinge. They did come without holes so I had to drill each one. I mortised them into the wood framing and applied epoxy under the hinge mounting surface. They were pricey compared to zinc,
Dan
prohandyman
Images: 785
Postby Jst83 » Mon Dec 28, 2009 5:57 pm
prohandyman wrote:They were pricey compared to zinc,
Will zinc work just as well for an outside hinge? Didn't think the price was to bad for a 6' hinge that I could split in 2 and do both doors
Jst83
Images: 215
Postby prohandyman » Mon Dec 28, 2009 6:16 pm
Zinc will rust over time
Dan
prohandyman
Images: 785
