A Question for the router gurus
After receiving my hatch hinge (from Grant), I now realize that the wall in the hatch area needs to be trimmed. Either that or the hinge shimmed up.
My plan for trimming this area is to make two (or more) passes with a router. The first operation will be with a rabbit bit, the second with a flush trim pattern bit (top bearing). Of course the ends of the cut will have to be squared up with a chisel. One problem I see with this approach is that the rabbit bit takes off 3/8” of material, I was thinking ¼” would be plenty. The wall thickness in the area to be cut is 1”. Does it sound feasible to attach 1/8” aluminum across part of the wall thickness to act as a shim under the bearing of the rabbit bit thereby decreasing the depth of the cut to ¼”, then removing the aluminum shim and making the pass with the pattern bit. Or would it be just as well to take off the full 3/8” and make up the difference with trim and rubber seal?
I’m sure if Steve Fredrick sees this he will advise me of a better way. I hope…
