Water tanks
Water tanks
Postby rwelp » Tue Jan 05, 2010 11:38 pm
I remember coming across a formula for calculating how much water you can put in either a round or square material, but now I can't find it. Any help would be appreciated
Rob Welp
Rob Welp
Build Pics
rwelp
Images: 66
Re: Water tanks
Postby bobhenry » Tue Jan 05, 2010 11:46 pm
rwelp wrote:I remember coming across a formula for calculating how much water you can put in either a round or square material, but now I can't find it. Any help would be appreciated
Rob Welp
http://www.russellwatergardens.com/Instruction/watervolume.php
This should help !
Postby bobhenry » Tue Jan 05, 2010 11:58 pm
Postby doug hodder » Wed Jan 06, 2010 12:34 am
It's Wickipedia, but might help....also, 1cu ft. = 7.48 gal., for a tube. pi x r squared by your length for cubic inches.
http://wiki.answers.com/Q/What_are_the_ ... allon_tank
Postby Lou Park » Wed Jan 06, 2010 7:42 am
Try this.
http://wscope.com/convert.htm
Ive been using this program for years and it's invaluable.
Lou
Lou Park
Images: 5
Postby wannabefree » Sat Jan 09, 2010 12:54 am
If you're comfortable with metric, 1cc = 1ml. Calculate the volume in cc, which also happens to be the number of ml. Then convert to gallons.
Well, that's how I'd do it. But then I'm nuts. :lol:
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby Mike_La » Sat Jan 09, 2010 4:31 pm
Not sure, but I think it's (L x W x H) / 231
or
On-line water tank capacity calculator
Mike
"Believe you can and you're halfway there."
Theodore Roosevelt
Mike_La
Images: 71
