hatches
hatches
Postby eaglesdare » Thu Jan 21, 2010 2:44 pm
my car is an hhr, so the back hatch opens up. is there any reason why i could not put a hatch to open up in the front of a tear instead of opening in the back?
using the term "tear" as in general. still not sure if i am going for a curve or more flat form.
but was just thinking of using space between both hatches (with out having to unhook tear and turn around. maybe putting tarp over in case of rain of extremely hot, sunny weather.
Louella
May the foam be with you.
eaglesdare
Postby asianflava » Thu Jan 21, 2010 3:41 pm
Do a search on this site for "Jim Dandy" it has the galley in the front.
asianflava
Postby planovet » Thu Jan 21, 2010 4:05 pm
The beauty of building your own is that you can do anything you want. Go for it! :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
Postby Mightydog » Thu Jan 21, 2010 4:08 pm
Post pix as you build it!
Mightydog
Postby eaglesdare » Thu Jan 21, 2010 5:07 pm
Mightydog wrote:Post pix as you build it!
everyone deserves a good laugh, right? :lol:
Louella
eaglesdare
Postby Ageless » Thu Jan 21, 2010 5:18 pm
You could make the hatch on the trailer long enuf that if you open it first then open the hatch on the car, the would overlap creating a dry galley area.
Ageless
Postby planovet » Thu Jan 21, 2010 5:29 pm
The only problems I see with the galley in front is having the tongue in the way and sealing the hatch. Of course, a removable tongue with correct one problem. You wouldn't be able to use a traditional hurricane hinge in that configuration either, especially driving in a heavy rain. :thinking:
ImageMark (& Cindi)
planovet
The Cat Man
Postby Mightydog » Thu Jan 21, 2010 5:41 pm
Everyone else laughed at us! We need the validation.
Mightydog
Gear hinge!
Postby eamarquardt » Thu Jan 21, 2010 5:43 pm
As far as a hurricane hinge not working in the front of a tear goes a gear hinge:
http://www.abhmfg.com/templates/pc-9-co ... inges.aspx
will solve this problem. So. Cal. Teardrops uses gear hinges on their galley hatches.
Gus
eamarquardt
Images: 150
Re: Gear hinge!
Postby eaglesdare » Fri Jan 22, 2010 8:40 am
eamarquardt wrote:As far as a hurricane hinge not working in the front of a tear goes a gear hinge:
Gus
i may have to get back to you on that one (if i do a hatch in front). that was a list of things and i wouldn't even know where to start to pick.
thanks. i sure hope you all are up for helping a person with zero knowledge on this one. i know once i start i am going to be asking questions and more questions.
hubby will help i am sure, but i am not convinced i want his help on this one (well not some of his help). he will try to take over and over build. i can't have that in this because of the weight issue. he built a run in for our ponies and i swear he could run his truck into it and not damage the frame at all. if we have a tornadoe or hurricane that is where i am going to hide out. :lol:
Louella
eaglesdare
Postby bobhenry » Fri Jan 22, 2010 8:56 am
Postby eaglesdare » Fri Jan 22, 2010 10:17 am
thanks, bobhenry, that one is nice.
Louella
eaglesdare
Postby prohandyman » Fri Jan 22, 2010 10:35 am
You mean this one...
Dan
prohandyman
Images: 785
Postby eaglesdare » Fri Jan 22, 2010 10:37 am
prohandyman wrote:You mean this one...
nice, thank you :)
Louella
eaglesdare
Postby bobhenry » Fri Jan 22, 2010 11:01 am
I think a 1 piece hatch would be preferable and would eliminate the center seam and sealing problem.
A removable tongue would be a wonderful thing also.
The extended hatch would also offer a bit more shade
and weather protection in the open position. My chuck
wagon has a similar hatch and the hinge points will be
weatherproofed just like I did Chubby's galley hatch.
