My plan is to build a pretty typical tear drop, less galley out of foam glued together, and cover it with glass mat and resin. I realize will be difficult to bend the ridged foam for the curved top. I have a plan to cut the foam in the rounded teardrop shape. The top foam will be about 2 inches thick and made up of several foam sheets glued together and cut to profile with a heated wire.
I plan to use a hardwood wooden brace glassed across the front floor where the tear drop body meets the tongue, and also some 1X2 bracing glassed in around the door and windows. The rest of the body will be foam and fiberglass to keep weight down.
Once the outside is done. ( less paint and details) I will turn it over and install interior, electrical, and simple cabinets. I then plan on attaching a floor fiberglass and foam floor brace horizontally with some simple 1 X2 wood strapping. it will then rest on a light weight frame like Andrew has shown us. indeed it will be much like the PICO plans Andrew has shared with us, but will use the fiberglass over foam construction. ( Thanks Andrew
What weight and many layers of glass do you think I will need? any pointers or tips? Think this can reasonably be done?
I plan to pull this behind my 2010 TDI Jetta at 80-85 mph, and i want it light and low.
Thanks..
