Ageless wrote:625 rpm isn't slow; that's yer basic problem.
chorizon wrote:Ageless wrote:625 rpm isn't slow; that's yer basic problem.
I prefer single flute countersinks.
I wouldn't turn much over 150RPM.
A "light feed" is part of the problem; slow feeds will cause a countersink to want to chatter.
If the above parameters are adhered to and the finish is still galled, then there is a lack of lubrication. Motor oil will work pretty well for lubrication.
In many instances we'll use 30 weight non-detergent motor oil for many "manual" countersinking and tapping applications.
afreegreek wrote:I don't know if this is the style of single flute CS you're talking about but they work good. we use this style for lexan, plexiglass and other plastics.
http://www.aircraft-tool.com/shop/detai ... T_ID=ZFC02
yes, one cutting edge is "single flute" and Kerosene can be used as a lubricant in certain cases. the old timers used it with oil stones to sharpen plane blades and chisels as it won't make mess on wood like oil does but on a drill press?? not sure. it doesn't matter what the CS cost, it matters what material it's made of. carbon steel will dull extremely fast in a drill press on metal due to heat, it's more for wood and plastics. High speed steel is what you need for metal. if you can find one, a three jaw brace and some elbow grease will work to finish off the holes with the CS you have or even a 3/8" cordless/plug in drill. or you could take your material to a metal fab shop and get it done for a case of beer..or you can just but a new one at the link I gave before. it will work really well and it's just postage plus the cost of the bit. about $15.00Muggnz wrote:I'm using a bit with one cutting edge. Is this a single flute? It was brand new about 25 holes ago, costing $40. However maybe I've blunted the cutting edge with the faster speeds I've been using. Sounds like I need a new slower drill press.
I tried with kerosine lubricant on the bit earlier today. ( A local recommended it over lunch ). It made a little difference on the 2 holes tried, by reducing the burr by about 50%.
I have been drilling pilot holes of around 4mm. With the countersinked hole being around 10mm.
neither of the 2 local hardware stores I discussed this problem with have mentioned hand held chamfer/debur tool. They were small to medium sized. I'm hoping to get to a larger store tomorrow.
david
Larwyn wrote:For aluminum the attached chart recommends a 5 flute countersink bit at 250 rpms with firm pressure. That's very close to what seems to work for me.
http://www.ibiblio.org/twa/info/drillSpeedChart.pdf
ya, the soap isn't the best option but in the case of our shop where the main thing is high end wood work it's the safest option. cutting oil has a way of traveling around the shop and contaminating the wood. it's just too much risk for us to take. that's the reason the CS I linked to is the one that works the best for us because it has a rake to the cutting edge (like a drill bit) and cuts the material rather than scraping it off. the only time it causes a problem is when the material isn't clamped well as the CS will actually dig in and lift the material.. good to hear you got something that works to your satisfaction..Muggnz wrote:yesterday I showed some of my later attempts at countersinking, to a friend. Which whilst I new were better than the earlier failures. I still thought that they still weren't very good. It turns out that he ( a few years ago ) trained as a machinist. He told me that my latest attempts were as good as I needed.
So this morning I started countersinking the holes for my trim, with a 5 flute bit. All counterinking holes were pre-drilled with a 3.5mm pilot hole. What I found was :
- soap as a lubricant didn't work very well for me
- applying cutting pressure & easing off helped
- too much drilling oil ( spray ) made the bit chatter, produce a very rough cut which I couldn't fix & occasionally produce a hexagonal hole
- to little drilling oil & the drilling was very hard
- just the right amount of oil & I got a good clean & quieter cut. Unfortunately this didn't happen as often as I'd hoped for
- spraying the oil directly onto the bit and/or the ali created to much oil on the cut for the first hole
- spraying the oil directly onto the bit only lasted 4 holes, before needing repeating
- even the moderate pressure I was applying, caused the end of the bed furthermost from the pillar of my drill press to sink a couple of mm. A block of wood fixed this.
- countersinking to around 20% of the hole size. AND dipping a finger on the oil & wiping the finger over the cut gave a reliable & mostly repeatable burr free cut. H&S comment - I did not place my finger under the bit, I pulled the ali out of the way before applying oil
- using a 13mm drill bit with my hands, I was able to de-burr what little burrs I created. A larger bit would've been easier to use.
- black sealant hides a few features.
david
Users browsing this forum: Google [Bot], Jimbodub and 2 guests
