cks-1 wrote:redneck trailer supply had been carrying a smaller version,but the cost wasn't much less.I stopped listing the doors you found,the same i have sold because of the listing/final value fees.and the free shipping expense.If your willing to buy outside of ebay/paypal i should be able to save you some money,i will be going to elkhart friday or monday to pick up a load of supplies,i can bring a couple extra doors back for you.i will need your ship to info to see if the savings is worth it to you. send me a PM
Newman39Fan wrote:
I really like the look of these doors, but it appears the bottom window is the one that opens. Therefore using the build method above the first 4 inches of your screened window is blocked by the mattress and your body/blanket would block even more. This would greatly reduce the amount of air that would flow through the screen.
So if you have these doors is this an issue or did you mount the doors higher up?
Thanks
len19070 wrote:I did a cost breakdown once on what it costs to build a door.
Lock & hinges $75
"C" channel @ $10 for 8' $40
Alum flat stock $20
Window, delivered $90
Miss. sealant, screws, etc. $10
I couldn't build a door like that for $15
Those doors are a bargain.
Happy Trails
Len
Arne wrote:If driving rain comes in, there is a design problem... I use Steve Frederick's door seal design and have gone through extremely heavy rains and strong winds with no leaks.
I like the looks of the windows but still prefer wood with piano hinges and lil bear windows... personal preference... 6 years, no maintenance. so far.
I figure 15/hinge, 40/window, 20/handle, 20/wood.... $95 vs $250.
And less chance of smash and grab. and if the window breaks, 40 to replace.
