Newman39Fan wrote:Thanks for all of the tips - and Afreegeek I went with option one of your list - bed.
To clarify a little I meant 2x2’s not 1x2’s. I have so many designs for this darn thing in my head right now that I typed in the wrong thing.
Yes the drawings above are what I am doing. I was going to coat the bottom edge of the sidewall with the roofing tar before setting it on the frame just like the flooring. With the 2x2 clarification you might see why I was saying bolts, would have been hard with 1x2. I am OK with using screws, but bolts just seemed more secure. I can’t wait until it warms up and I can start actually building instead of driving myself nuts with all the build options!!
yup, 2x2 would be better than 1x2. any time you can increase the size of a joint's interface the stronger it will be. the only thing I would do differently than I already described is add a 3rd bead of adhesive along the joint. the more adhesive the better as long as you don't use so much it squeezes out all over the place and makes a mess.
you can use bolts if you want. I can't imagine how that could cause you any problem but it won't really strengthen the joint in any significant way because the adhesive has way more holding power than any type of mechanical fastener. screws are quicker and easier to install and a lot cheaper than nuts and bolts.
something that may interest you if you decide on bolts....
T-nuts. they are a nut and a washer in one and they have little pins that dig into the wood so you don't need a backup wrench to hold the nut as you tighten the bolt. they also sit flush with the surface.
http://www.jamestowndistributors.com/us ... o?pid=1746
sealing the edges of the ply. you can use all sorts of things, tar, caulking, epoxy, paint. all these thing will work. the most important thing is you use something. this is the weak spot in the plywood and your trailer where water will do the most damage..
