5x112 trailer hub availability in US...?
Postby Vgonman » Thu Feb 04, 2010 3:54 am
I own various VW vehicles with 5x112 bolt pattern (Vanagons/Passat) and would love to have rims on the trailer that match my tow rig. How easy/difficult is it to get trailer hubs with that bolt pattern here in the states?
Sorry if this has been asked/answered in the past...
Sean B.
Vgonman
Postby emiller » Thu Feb 04, 2010 6:43 am
You can call one of the axle manufacturers and ask if they can make them for you. I don't know about VW very much so I don't know if the bearings would fit on to your trailer hub. :thinking:
emiller
Images: 157
Postby vwbeamer » Thu Feb 04, 2010 11:48 am
vwbeamer
Postby angib » Thu Feb 04, 2010 1:23 pm
The British manufacturer of Flexiride does list a 5 x M16 x 112 PCD hub (M16 is a big stud, ~5/8"):
http://tinyurl.com/2t7e67
However these are half-axles with an 1800kg (3960lb) capacity, plus then you have the horrific shipping costs to the US, so it's not really a good idea.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Dale M. » Thu Feb 04, 2010 6:38 pm
You could have a "standard" hub redrilled and reuse studs for your 5 on 112mm pattern... Perhaps you can find manufacturer that can supply blank hubs or is willing to do a "custom" drilling.... Any machine shop should be able to redrill almost any available hub...
We do it all the time to fit different wheel (ford and chev) patterns to our VW dune buggies ( early VW (69 and later) with 4 lug hubs and drums ) ....
Dale
Dale M.
Images: 18
Postby High Desert » Thu Feb 04, 2010 10:47 pm
Here's another adapter option for you to look at. I'd like to do the same thing. Similar price to what vwbeemer mentioned too.
http://www.ezaccessory.com/Wheel_Adapter_5_Lug_4_5_To_5_Lug_112_p/5450-5112.htm
Shaun
High Desert
Images: 27
Hubs
Postby eamarquardt » Fri Feb 05, 2010 12:25 am
A while back I modified some hubs and rims for "Big" Guy (Teardrops for Vets). Toyota uses a 5 X 4.5 on some of their vehicles. He wanted to use Toyota alloys to match his car on his trailer. We drilled out the holes for the studs to 14mm (as I remember) and pressed in metric studs. We also had to bore out the hub of the rim to fit over the hub of his new axle so you may also have to bore out your rims to fit over a trailer hub. In addition, the trailer hubs stick out more so you probably won't be able to put the original hub cap back on.
However, if you want to procede, check with Century Wheel and Rim in the LA area and see if you can order an axle with blank hubs or brake drums.
Here is their web page:
http://www.qtrailer.com/locations.php?comp=CWR
click on the "undefined" dot in the middle of the Pacific Ocean on the map!
If you can find blank drums or hubs they can be drilled to any pattern you wish. If you can't find blank drums or hubs it would be possible (IMHO) to drill 5 new holes inbetween the original holes. If you need 4 holes that would present a problem unless you can find an axle with the capacity you want with a 4 bolt pattern.
If you want to procede I could do the machining on my mill and it would take a morning or so. I'm in Simi Valley about a hour North of you. PM if you have more questions.
Gus
eamarquardt
Images: 150
Users browsing this forum: Google [Bot], Jimbodub and 3 guests
