wet behind the ears/ultra light TD ?
Postby rmcelroy » Sun May 22, 2005 12:24 pm
Hello all, I'm new here. I have a Miata and would like to build a TD that a motorcycle could pull.
My early thoughts are 2x2 alum frame w/ 1/2 inch floor, and stub axles. A 1x1 frame for the body of the trailer skinned with Aluminum and lined on the inside with bendable luan insulated with 1 in styro. Most of these ideas come courtesy of TDparts.
I have been reading up on fiberglass and aluminum contruction and feel the aluminum is the way to go-or would double wall luan be just as good (see thats why I need advise).
Excuse me if this has been beat to death, but I didn't really find much in history searches (may have not looked for the right words)
Thanks in advance
Regie
Wheather you think you can or you think you can't, your right.
Henry Ford
rmcelroy
Images: 27
Postby Guest » Sun May 22, 2005 12:55 pm
Regie,
Contact Steve Wolverton... His couper tipped the scales somewhere between 500-650 lbs. (Can't remember for sure, but it was light)
Check with Asianflava too, he did some really nice sandich construction that helped out in the weight department.
Guest
Re: wet behind the ears/ultra light TD ?
Postby angib » Sun May 22, 2005 4:44 pm
rmcelroy wrote:Hello all, I'm new here. I have a Miata and would like to build a TD that a motorcycle could pull.
I hope Gerald Hynes from Canada will post a reply here as he towed his first trailer with a Gold Wing. This is what he said in an email to me:
"Teardrops are fine for motorcycles. I have over 20,000 km on the clock with this beauty in tow. Has solar charging, 7" widescreen LCD TV with DVD and surround sound. Made for one but sleeps 2 in a pinch (very cosy!). The agro of towing rapidly disappears when you open the door, get in and watch a great action flick on the telly!"
And here is his trailer:
Andrew
angib
5000 Club
5000 Club
Images: 231
