by eamarquardt » Thu Feb 04, 2010 9:12 pm
Some thoughts. If the walls are 3/4 inch they'll be thick enough to screw into. If you put down some masking tape or duct tape on the walls to protect them (but leave the area you want to sand uncovered) you could sand down the finish a bit and put some glue under any cleats you use to affix the bulkhead and shelf. That would make it bulletproof.
Hope this helps.
Gus
"Scientists have odious manners, except when you prop up their theory. Then you can borrow money of them." Mark Twain
Corollary:
"We all like it when someone agrees with us! But it's more important how you handle it when someone doesn't." Gus
