Page 1 of 2
Cover the trailer frame or not.
Posted:
Sat Feb 06, 2010 9:40 pm
by rwelp
I am looking for a general consensus. How many of you cover the trailer frame with the sides? The problem I am having is my frame is 3" c channel and if I use 4' ply for the sides I will be losing about 6" inside height(3" metal frame + 1 3/4" floor + spar and skinning material), thus making my inside height approx. only 42". Any thoughts would be appreciated. I am making a version similar to the LIL Diner, though not quite as long and it will have a drop down floor.
Rob Welp
Posted:
Sat Feb 06, 2010 9:50 pm
by halfdome, Danny
You could spline the extra inches to the top of your profile and a lot of it will be removed when you cut out your profile.
I personally prefer covering the chassis, it gives a polished look to the teardrop.
Danny
Posted:
Sat Feb 06, 2010 9:54 pm
by rwelp
Thanks Danny,
That's what I thought too, I just hate the thought of losing that inside height.
Rob Welp
Posted:
Sat Feb 06, 2010 11:05 pm
by RonS
Use 5 foot wide plywood and cover the frame and still have more headroom than with 4 foot plywood not covering the frame?
Posted:
Sat Feb 06, 2010 11:32 pm
by Gage
rwelp wrote:Thanks Danny,
Rob Welp
So when your sitting down, how much height do you need, or do you plan on standing up in your teardrop? Sometime when you get a chance, sit down somewhere and have someone help by taking a measurement from the bottom of you butt to the top of your head and then add 3 inches. That’s how much room you'll need above the mattress.
P.S. My sides are dropped over my frame 6" and I have an 8" mattress with still plenty of room inside to move around and play.
Posted:
Sat Feb 06, 2010 11:36 pm
by afreegreek
no reason a person couldn't mount the sides flush to the bottom of the floor and skirt it either. anyway, 5' x 10' ply isn't rare or hard to find.. just look in the phone book for a supplier in your area.
Posted:
Sun Feb 07, 2010 12:34 am
by artwebb
It is in my area! Of course, I live in a town with a pop below 6000 at last count. Skirting is a good suggestion, though, and I personaly think a tear can look good with or without the frame exposed, depending on the other design elements, and how pretty or ugly the frame might be
Posted:
Sun Feb 07, 2010 6:42 am
by rwelp
The reason I am concerned with the height inside is that I will have a drop down floor and raised seating/bed like Mike has in the Lil Diner. With the bed raised 6-8" above the floor, I am concerned about headroom. I will however follow your advice and have my wife measure me when sitting.
Rob
Posted:
Sun Feb 07, 2010 6:48 am
by prohandyman
Rob
Just attach a piece of 1x4 trim (if a woody) or a piece of aluminum diamond plate (if using aluminum) to cover the frame side.
Gage....your too old for play!
Posted:
Sun Feb 07, 2010 6:59 am
by rwelp
afreegreek wrote:no reason a person couldn't mount the sides flush to the bottom of the floor and skirt it either. anyway, 5' x 10' ply isn't rare or hard to find.. just look in the phone book for a supplier in your area.
There is a source for 5' x10' ply in my area, problem is the 1/4 thickness has an mdf core and I don't want to use that, and I don't want 3/4 thickness for my walls. I may just have to scarf 2 sheets of 5' x 5' baltic birch ply if I decide to use 5' sheets.
Rob
Posted:
Sun Feb 07, 2010 7:04 am
by rwelp
prohandyman wrote:Rob
It will not be an aluminum TD, so the 1x4 may be the option for me if I don't go with a 5' sheet of ply.
Rob
Posted:
Sun Feb 07, 2010 7:16 am
by afreegreek
rwelp wrote:afreegreek wrote:no reason a person couldn't mount the sides flush to the bottom of the floor and skirt it either. anyway, 5' x 10' ply isn't rare or hard to find.. just look in the phone book for a supplier in your area.
Rob
look in the phone book, call a commercial millwork shop and ask them where they get their material from.. their supplier will be able to set you up.
Posted:
Sun Feb 07, 2010 11:02 am
by emiller
I cut down my sides a couple of inches and cover the frame. Too much head room other wise.
Posted:
Sun Feb 07, 2010 11:05 am
by doctor phreak
[quote="prohandyman"]Rob
at a cost perspective this is what i would do instead of buying 5 x 5 plywood....my .02
Posted:
Sun Feb 07, 2010 2:26 pm
by Gage
