by aggie79 » Wed Feb 24, 2010 10:05 am
Hi Rog,
I don't know how you plan to attach your walls, but poplar will hold screws better than yellow pine or douglas fir, or the edge veneers of plywood. As far as thickness/depth, 3/4" will be sufficient if you skin both sides.
On my floor, I used 1/4" plywood, but only glued (PL Premium) the wood crossmembers to the plywood, and did not glue the insulation. On my roof, I used 1/8" plywood top and bottom, but glued both the spars and insulation to the plywood. Even on the flat area of my roof, there is less deflection in the 1/8" plywood between the spars than there is in the 1/4" plywood between the crossmembers. So, I would say apply glue to the whole assembly.
One thing I have encountered with the 1/8" baltic birch plywood, is that it is so thin that it is "wavy" at times. The 1/4" is flatter. This may be something to consider in that the 1/8" plywood may be a little harder to build "flat" unless you build your floor on a workbench. Also, the "thinness" of 1/8" plywood gives some challenges on holding fasteners - particularly staples from an air nailer - unless you use some additional type of backing material.
If you use furring strips, you may want to bring a tape measure with you. In our area, a 1x2 is 3/4" x 1-1/2", but when you buy "furring strips" the actual dimensions are smaller than 3/4" x 1-1/2".
Good luck,
For build info on our former Silver Beatle teardrop: Build Thread
