Those of you with woodies -- what kind of wood did you use?
Postby misterW » Tue Feb 23, 2010 6:41 pm
and how did it work out?
I've been shopping around for plywood of different types and am curious what has worked out for other people.
misterW
Postby nevadatear » Tue Feb 23, 2010 7:36 pm
Used birch outside/inside. It was that or oak, the only two choices where I live. Liked the birch better. Cherry trim, oak galley cabinets. I am happy with it. If I had more money and more choice, may have gone a different direction.
nevadatear
Images: 171
Postby doug hodder » Tue Feb 23, 2010 8:23 pm
I used marine grade mahogany, I'm thinking 6mm laminated over 1/2" ply, dyed colonial red...has that vintage Chris Craft look. Doug
Postby afreegreek » Tue Feb 23, 2010 8:48 pm
doug hodder wrote:I used marine grade mahogany, I'm thinking 6mm laminated over 1/2" ply, dyed colonial red...has that vintage Chris Craft look. Doug
heard you can get the original Chris Craft colour from one of the club websites..
afreegreek
Postby Miriam C. » Tue Feb 23, 2010 9:24 pm
I used Baltic Birch because I like the color and because I could get it in 5' x 5' sheets!
Postby Micro469 » Tue Feb 23, 2010 9:34 pm
I used Baltic Birch inside and for the roof. I used Big Box 2.7 mm Luan for the sides. The Luan is actually holding up better on the sides than the Birch on the roof......
John
Micro469
Images: 382
Postby d_lairson » Tue Feb 23, 2010 10:31 pm
how does the lauan stain up?
d_lairson
Postby Sam I am » Tue Feb 23, 2010 10:48 pm
I used Baltic birch too. It's great to work with. It's strong and takes all types of fasteners well without splitting out. It takes paint or varnish well too. I didn't try stain, but I'm pretty sure it would work well too. the 5'x5' sheets were handy for my 5' wide teardrop - very little waste. I recommend it highly. It can be a little tough to find, though.
Sam
Sam I am
Images: 106
Postby dwgriff1 » Wed Feb 24, 2010 1:16 am
Meranti.
Holds up well as long as you keep it dry!
dave
dwgriff1
Postby Rock » Wed Feb 24, 2010 7:41 am
Sapele plywood.
The plywood was cheap because I think it had been sitting around for awhile. The veneer was super thin, really dry and super fragile. It was a major PITA but not that it's encased in fiberglass and epoxy it's OK.
Eric
Rock
Images: 48
Postby Steve_Cox » Wed Feb 24, 2010 8:01 am
I used oak plywood and oak trim. Epoxy and polyurethane coated. 5 years and a couple of polyurethane recoatings. Sold it, new owner is sincere about doing the maintenance to keep it looking good.
Steve_Cox
Images: 196
Postby boomboomtulum » Wed Feb 24, 2010 9:57 am
I used Birch Ply. 4x9, Dyed and w/ 5 coats of McCloskys Marine Varnish. Trim is Maple 5/8 w/ Walnut Dowels. I keep it in doors when not in use.
Dave
http://www.mikenchell.com/forums/album_ ... c_id=37109
Have'nt been everywhere yet, but it's on my list.
boomboomtulum
Images: 50
Postby Mauleskinner » Wed Feb 24, 2010 10:10 am
I used 1/4" birch ply from Lowe's for the flat parts, and two layers of 1/8" birch for the curvy parts (had to go to "the Cities" for that).
Mauleskinner
Postby doug hodder » Wed Feb 24, 2010 10:41 am
d_lairson wrote:how does the lauan stain up?
It's up to you, remember, what you see is what you get when finished up. Any discoloration or flaw will show. It's a lot of work to get something that you potentially are not completely happy with in the end. Luan typically has a very thin veneer over a core. I went with the marine grade thin ply as the plys are solid material and more forgiving when it comes to doing any sanding/work on it and finish up much nicer. I wanted mahogany. It does cost more though. Much more difficult to sand through a ply layer than the veneer, is more stable and less likely to de-lam. If you sand through the veneer on a luan...you're sunk. Just my opinion. Doug
Postby Miriam C. » Wed Feb 24, 2010 8:09 pm
Rock wrote:Sapele plywood.
Eric
:applause: Oh that is very nice!!! :thumbsup:
