timlsalem wrote:Sorry folks, I'm still confused. End cuts are no problem. they're simple but the cuts I'm not clear about are the degree cuts made on the long edge of 2x4s and 2x2s. seems like any clamp down would get in the way of the cut. I guess I could start with longer stock and make the cut then cut those to length but, that is pretty wasteful of material. I guess it's pretty clear by now, I'm not the sharpest tool in the shed.
boomboomtulum Posted: Wed Mar 03, 2010 10:25 am Post subject:
Do you mean that your intent is to rip the 2by, doing a taper cut, from end to end regardless of the length?
If so you might clamp at least 2 -2x4s together so now you have a 2 x 8. Clamp from the under side so they will out of the way and low enough the blade will not contact clamp. You will use another 2by as a straight edge. Measure your saw from the outside of that bottom plate shoe (the piece that rides on the material) to the blade edge plus the thickness of the blade. Draw your line on the piece to be cut. Measure from that line to the measurement you just took on the saw ( from the outside edge of the plate to the blade + blade) clamp another 2by or plywood scrap (factory edge) that is long enough to make it in one pass, to the 2by you are intending on tapering. Now you built a fence that your 7 1/4 will ride against.
If those 2 measurements are correct your blade should be on the mark you made first, the spot where you intend to make your cut. Set blade to just clear through the cut. Make sure clamps are out of the way. Watch where your fingers are, put on your safety glasses, have 911 on speed dial and start the cut. There are many ways to cut a board but with your saw you can make rips. If this is not what you wanted, try a google search on How to....
Dave
timlsalem wrote:found a 10" table saw at Harbor for $99. probably the way to go. Won't have to mess with jigs.
