Greg M wrote:Heres a program that will print out a paper template of the joint you want to cut. Just put in your tube sizes, and the angle you wish to join them at, and it does all the thinking for you.![]()
Just wrap the template around the tube, mark it out, then rough out the opening with a drill/grinder/snips, and file to fit. I used it to make all the joints on my bikes.
-Greg
