glassice wrote:If you use silica sand won't it be a pain to sand. No bonding to the sand I like talc Talc is the major component of any body filler. is a sandable filler added for fairing and smoothing the finish of fiberglass laminations. The recommended filler ratio is 2 parts talc to 1 part resin to result in a smooth, creamy semi-paste. The exact filler portion will vary by application depending on the desired consistency. Allow to stand one hour before adding hardener and using.
glassice wrote:IT looks like your on the snowier coast try 1.800.838.8984 fibre glast .http://www.fibreglast.com/ By letting it set, lets resin soak in to what you are using
Reddiver wrote: is a wood style and I would like to keep it as clear as possible
that's been my experience too.. as far as I know, the only way to get thick epoxy that is clear is to let it set a while in the pot.doug hodder wrote:Reddiver wrote: is a wood style and I would like to keep it as clear as possible
It's been my experience that anything added to the epoxy to thicken it will show that color once cured. Others opinions may vary. Doug
afreegreek wrote:that's been my experience too.. as far as I know, the only way to get thick epoxy that is clear is to let it set a while in the pot.doug hodder wrote:Reddiver wrote: is a wood style and I would like to keep it as clear as possible
angib wrote:
All fillers must, without exception, be added to epoxy that has already been mixed with hardener. If you added the filler(s) before the hardener, there is no way you will get an even mix (unless you are using a power mixer) and so you will have spots that don't cure properly.
Andrew
