I'm attempting to design and,hopefully, build a lightweight teardrop. I can rough out the design just peachy, it's the construction method I'm having problems tripping over.
What I'm looking at is using a home made laminated wall. Plywood (type to be decided) wrapped around a foam insulation. No "studs" just the laminate. Roof would be wraped around a normal frame like I see is done on most trailers. I'd also like to build it with out the frame, using basicly a triangle with the axle on one end and the hitch on the other.
The questions. Would this kinda of laminate structure hold up long term(mulitiple years at least)? Would it be sound enough to survive driving around at reasonablely high speeds? What materials would be suggested for this kind of idea?
Thank you in advance
Pardon my noobishness.
