Stain and Glue
Stain and Glue
Postby alftinc » Thu Mar 25, 2010 4:02 pm
Has anyone out there glued bare wood trim to a surface that has been stained with oil base stain such as minwax stain, but not varnished yet?? The stain is dry. Would Titebond II work in a situation such as that??
alftinc
Images: 7
Re: Stain and Glue
Postby Miriam C. » Thu Mar 25, 2010 4:27 pm
alftinc wrote:Has anyone out there glued bare wood trim to a surface that has been stained with oil base stain such as minwax stain, but not varnished yet?? The stain is dry. Would Titebond II work in a situation such as that??
Depends on how much stress your wood piece is under. Definitely give it a sanding. I had trouble with varnish sticking in some places where I had Minwax. Don't really know why. Had to sand it really wall and re-varnish.
Postby wannabefree » Thu Mar 25, 2010 11:24 pm
I would recommend polyurethane in that situation. When in doubt it is always a good idea to make a test piece. If your stir stick is still handy, glue a piece of trim to it, whack it with a hammer and see what happens.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby afreegreek » Thu Mar 25, 2010 11:30 pm
yes
afreegreek
Re: Stain and Glue
Postby afreegreek » Thu Mar 25, 2010 11:47 pm
I'm not familiar with "consumer/retail" products like minwax. everything I've used is commercial stuff so I might be way off here but, it's likely you didn't wipe the residual stain off well enough or you wiped well but did it too late and left a residue of pigment on the wood's surface. this is pretty much the same as a coat of dust as far as a surface for finishes and adhesives to adhere to..
afreegreek
