Stinky plywood.
Well it's been ~five months since the build. The inside has always had that chemical smell. I let it air out as much as possible.
There was a time during the build when the smell first happened. I do believe it was from a piece of 3/8 cheapy ply that I used as the doors jamb/frame/stop.
I was too involved with the build to think twice about it. I chalked it up to new plywood with a fresh cut. Also thought that the smell would soon go away.
Speed up to today. I removed the two pieces and took a big whiff. Yuk.
It was still damp. They are now setting in the sun hopefully drying out.
I say that they are damp due to the darker golden color. Dry plywood blondes up a bit. At least to me.
While the pieces are drying I have the cargotear closed up so I can have a whiff of the inside a bit later on. I should be able to tell immediately if my mission is a success. I did spend a bit of time smelling different parts of the wooden structure. I think I got a splinter on my nose. Ouch.
I'm kinda adamant about solving the dilemma. Our 8 yr old wants to turn it into a full fledged sleeper with a galley.
I may get some 1 x 3 for new door stop if the plywood doesn't dry out.
I used the sdtripper2 sticky's for info but didn't find exactly what I needed.
Anyone else have the stink eye from stinky plywood?
