Unit to be separate from trailer frame?
Postby DogStar » Mon Apr 12, 2010 4:29 pm
Hi All!
I have been reading and reading many of the build threads. So inspirational! Seriously 8)
My first and major question and I have not yet seen a build thread on this idea, so if there are some please point them out.
What I would like to do, still in earliest planning stages, is to build a Tear Drop design but have it removable from the trailer frame. The trailer would need to do other duites such as haul building materials, transport motorcycles etc...
I am thinking possibly a "landscapers" style trailer (they are fairly plentiful around here). I envision a Tear Drop appx 9-10 feet long and typical width 4+ to 5 feet wide.
Size in part defined by the frame size.
Do you think it possible and feasible to build a self contained unit that could "slip into" position and then be bolted down when used as a travel trailer? :thinking:
I am an ex-woodworker, currently a dog trainer.
Appreciate any leads or thoughts on the concept.
Yours in road travel,
Eric
Always with my thanks,
Eric
(aka DogStar & ELDogStar)
DogStar
Images: 5
Postby regis101 » Mon Apr 12, 2010 5:44 pm
I built the box and then set it on a 4 x 8 TSC utility trailer with the same intent as you. Four bolts and it's all good. The box is plenty strong and still lightweight. Browse through my link for a look.
Peace, Regis
Livermore, Ca
Working on Build #2
regis101
Postby DogStar » Tue Apr 13, 2010 3:11 pm
regis101 wrote:I built the box and then set it on a 4 x 8 TSC utility trailer with the same intent as you. Four bolts and it's all good. The box is plenty strong and still lightweight. Browse through my link for a look.
Appreciate that Regis.
Seems like it is not a common occurrence.
But looking at lots of the "builds" it is also becoming obvious that many units are plenty strong enough to do this.
Now my search for a trailer begins in earnest. How big/small will it be? Only time will tell what I find in acceptable condition.
Again with my appreciation,
Eric
Eric
DogStar
Images: 5
Postby Grid Runner Adventures » Thu Apr 15, 2010 9:06 am
Im building a 6ft by 8ft camper that will bolt onto a 4ft x 8ft harbor freight trailer.
removable for hauling other items etc.
http://tnttt.com/album_ ... r_id=10334
there's my pic's of what it will look like,
composting toilet is a nature's head
www.offgridrving.com
Follow my build of a off grid camper that is 6x8 and I will live in it for an entire year!
Google Is My College
Postby Shadow Catcher » Thu Apr 15, 2010 4:55 pm
The Microlite Wazat is built that way and the frame for both capsule and trailer are aluminum.
Postby TwilightLane » Sun Apr 18, 2010 9:50 pm
Regis - you only use 4 bolts to attach the body to the frame??? Am I reading that right? I used 13 bolts and construction adhesive - and was worried it wouldn't be enough!! :lol:
Rob & Lori
Aspen & Tundra
My Instructable: http://www.instructables.com/id/Teardro ... l-Trailer/
TwilightLane
Postby 2bits » Sun Apr 18, 2010 10:36 pm
I used 4 bolts to hold mine to my frame. I would think as long as your body was rigid enough to move and you didn't have space to just build/get another trailer, and you had a hoist I would think it would be easily doable. Just keep the fenders mounted to the frame, not the body (or both like mine :shock: )
Thomas
2bits
2bit Member
