doug hodder wrote:I've got Coleman white gas stoves and drill the foot bumps on it and through bolt it with a wing nut...makes it removeable. You'd want to make sure that there is an air gap under your stove. Doug
tk wrote:When you build your cabinets, keep the bottom lower than the face-frame edge rather than making it flush (this will keep things from sliding against the doors) and build your shelves (both fixed and adjustible) with a lip protruding above the shelf. For keeping doors shut, I have seen two excellent products but I only know them by their trade-names: Southco and BullDog catches. If you use toddler safety latches, make sure you do not get the kind that you must open part way before you can release the latch.
Best,
48Rob wrote:DH,
Basic simple cabinet catches, friction, or magnetic, should be enough.
A stove should be fine with rubber feet.
A microwave should be fine with rubber feet, but could be further secured with a bracket if top heavy.
If you have trouble with things flying about, the suspension system on your trailer may need attention/fine tuning.
You can drive down the road in your car, with a coffee cup in the cupholder...without it ending up in the back seat.
Your trailer suspension won't be quite that soft, but things shouldn't "move around" and doors shouldn't open by themselves.
If you have a trailer that rides hard, and you can't adjust the suspension, then brackets to secure appliances and positive latches on doors may be needed.
If they are, just bolt 'em down so they'll be where you left them when you get there!
Rob
