Aluminum question from a newbie
Postby saladgirl » Sat Apr 17, 2010 10:48 pm
I live in Ohio, and I noticed a number of trailers are made of shiny aluminum. I was wondering if it pits if exposed to road salt/acid rain? Does it have to be coated with something, or is that not a problem?
Just curious...thanks, Sally
saladgirl
Yes
Postby eamarquardt » Sat Apr 17, 2010 11:00 pm
Virtually anything will pit and corrode if exposed to road salt and acid rain and the corrosives are not washed off.
If you keep the al as clean and dry as practical the al will look good for a long time. You can always polish it with various compounds to clean it up. A coat of wax will also help. But if you ignore it, don't keep it clean, and let the corrosion gain a foothold, it will deteriorate.
Hope this answers your question.
Gus
eamarquardt
Images: 150
Postby Shadow Catcher » Sun Apr 18, 2010 6:53 am
While I like the idea of aluminum the care and feeding is a bit more than I wanted. I like Filon, an FRP (fiber reinforced polyester) used on among other things truck bodies and many/most RV's.
Postby Endo » Sun Apr 18, 2010 9:35 am
Hi Sally,
My first teardrop was "raw" aluminum or also know as mill finish aluminum. That teardrop showed every scratch, fingerprint, dirt or dust particle.
My current teardrop is anodized aluminum with a brushed finish.
It is much easier to keep clean or at least it appears clean even when it is not.
The brushed finish hides a lot.
It doesn't show finger prints, scratches or dust nearly as much.
I don't think I will ever use mill finish again.
I feel the additional cost of anodized is worth it.
I still like to wash the camper after each trip.
I also store it indoors which helps as well.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
