48"slide-out
48"slide-out
Postby Ageless » Mon May 10, 2010 4:59 pm
First off; after the Dam Gathering; I've put the Palace on the back burner and pulling out the plans for The Zephyr.
I plan on using the forward, slide-out galley. Tried finding 48" slide units but don't want to lay down that kinda $$. So to anyone who has built a slide out, how did you construct the slide?
Ageless
Postby rxc463 » Tue May 11, 2010 4:37 am
I have found the slides on popup campers to be very durable. They take a bit of time to salvage as most are all riveted units. Worth the time and effort if you can find one to tear apart.
Russ
Politicians and diapers have one thing in common. They should both be changed regularly, and for the same reason.
rxc463
Images: 20
Postby razorback » Tue May 11, 2010 9:13 am
Charles, (coca-cola teardrop) has built a couple of side slide outs that are for a queen size bed. Also I remember another slideout. The member built his to slide out the front. The trailer was extended in the front. I think he hauled a motorcycle on the front and after it was unloaded he pushed the front slideout on a couple of pipes built into the floor of the trailer.
Larry
razorback
