by Michael W » Tue Jun 07, 2005 7:25 am
Power tools, by their nature, are dangerous. You only have to watch this forum to learn that lesson. That does not mean they can't be used safely, just respect them and use your common sense. Read the user manuals (this can be quite entertaining at times) and follow the instructions. More importantly, listen to that voice in your head, if something does not feel safe, it probably isn't.
If you are learning new skills while building your teardrop, I advise that with any new step, practice on scrap pieces. Build a prototype. This increases safety and the craftsmanship of your project. How you ask? By practicing first, you will not be as nervous when you cut into that expensive 4X10 sheet of plywood.
Tell me if I sound like I am preaching, but you asked. Always wear safety glasses when working in your shop and don't forget hearing protection when running power tools. While that table saw or belt sander may not sound too loud, hearing loss is cumulative.
Regarding the dangers of towing the trailer, make sure the coupler is fully seated and latched on the ball and use safety chains. Also, check your lights frequently. A periodic inspection of your frame is not a bad idea. If it is a bolt together style, check the torque on the nuts to assure none are getting loose. If it is welded together, check for cracks. Another item to be concerned about are the lug nuts. They can back off, especially on brand new trailers. Double check them after a few hundred miles. Finally, don't forget to grease those wheels bearings.
Michael W on Tue Jun 07, 2005 1:43 pm, edited 1 time in total.
