I stumbled upon this while researching.
A nice, short, informative article on Baltic Birch.
http://www.woodworkingseminars.com/wp-content/s7334.pdf
mikeschn wrote:I had a serious problem with baltic birch. It delaminated in the rain. And that was with CPES and a good Oil based paint on top of it.
BillZ wrote:mikeschn wrote:I had a serious problem with baltic birch. It delaminated in the rain. And that was with CPES and a good Oil based paint on top of it.
So, Would you say that using BB for the Gen Ben plans is now in question?
I just bought a couple of sheets for the floor and 1 sheet for the cabinets as recommended. Should I switch to an exterior marine grade?
afreegreek wrote:I've been in the commercial millwork/cabinet making trade for 25+ years, most of it in the ultra high end where money is not a consideration and about the only thing I've used BB for is drawer boxes.. what we do use it for though is jigs and such for the shop. it's great for that but as far as fine ply panels go, there's tons of stuff out there that is waaay better than BB..
Classic Finn is correct too, not all BB is the same. the Scandinavian stuff is better that the Russian stuff. it's like that with all ply panels though, it's a manufactured material and it's the people putting it together that determines quality, not what type of wood it's made from..
KenC wrote:afreegreek wrote:I've been in the commercial millwork/cabinet making trade for 25+ years, most of it in the ultra high end where money is not a consideration and about the only thing I've used BB for is drawer boxes.. what we do use it for though is jigs and such for the shop. it's great for that but as far as fine ply panels go, there's tons of stuff out there that is waaay better than BB..
What type of ply would you recommend for the outside walls of a teardrop.
Thanks
I like the Meranti marine grade from this supplier..KenC wrote:afreegreek wrote:I've been in the commercial millwork/cabinet making trade for 25+ years, most of it in the ultra high end where money is not a consideration and about the only thing I've used BB for is drawer boxes.. what we do use it for though is jigs and such for the shop. it's great for that but as far as fine ply panels go, there's tons of stuff out there that is waaay better than BB..
Thanks
afreegreek wrote:I like the Meranti marine grade from this supplier..KenC wrote:afreegreek wrote:I've been in the commercial millwork/cabinet making trade for 25+ years, most of it in the ultra high end where money is not a consideration and about the only thing I've used BB for is drawer boxes.. what we do use it for though is jigs and such for the shop. it's great for that but as far as fine ply panels go, there's tons of stuff out there that is waaay better than BB..
Thanks
http://www.westwindhardwood.com/price_marine_ply.php
it's got all the good things BB has but it's much lighter and has the best glue and a #1 glue line. it's true that exterior grade uses the same glue as marine in many cases but the quality of the glue line in marine is much better. exterior has the minimum amount of glue and sometimes it's not good enough for a complete bond and there can be areas that are not properly bonded from the get go.. marine grade ply is the best of the best all around. from the quality of the veneer to the glue, to how much glue and the assembly.. it's meant to withstand forces and loads other ply products are not.
example..
static load - a wall,
live load - a floor,
dynamic load - a boat hull..
sure it cost more but it's not much considering the big picture. include all the materials and labour a finished TD involves and a few hundred bucks soon becomes minimal..
personally, I don't see spending hundreds on CPES and other crap in an attempt to protect cheap ply as a good investment.
BillZ wrote:afreegreek wrote:I like the Meranti marine grade from this supplier..KenC wrote:afreegreek wrote:I've been in the commercial millwork/cabinet making trade for 25+ years, most of it in the ultra high end where money is not a consideration and about the only thing I've used BB for is drawer boxes.. what we do use it for though is jigs and such for the shop. it's great for that but as far as fine ply panels go, there's tons of stuff out there that is waaay better than BB..
Thanks
example..
If you don't need to use CPES for this ply, how would you cover it? Would a simple primer and paint do?
