Glue suggestion needed soon
I am ready to put the final 1/8" (bottom) skin on my sandwich floor.
I have PL Premium, but no where on the tube does it say anything about using it on blue foam. All my framing and ply has been epoxy coated. I decided not to use the PL to install the blue foam between my floor frame members because I was not sure of compatability. I opted for thickened epoxy which took much longer.
I am now ready for the final skin and would like to use the Pl but, I need to know if it will work. I have spent too much time sealing everything to destroy the insulation because I used the wrong adhesive.
I can use the epoxy again but I would rather use something quicker.
Has anyone used PL Premium with success in this application?
Thanks,
Larry
Thanks,
Larry
