asianflava wrote:The couple inches lost to the insulation is worth it. No condensation problems which makes moisture which could lead to mold, better sound insulation, and it doesn't get as hot as fast.
Do what you wan to, I'm not saying that it's the olny way to build, but mine is insulated.
Miriam C. wrote:1/2 inch walls for a normal TD should be fine. The air and heater will more than be able to keep up. You don't have your residence listed so can't really answer to how hot or cold you might get.
nevadatear wrote: We are trying a box of humidity remover crystals for closets to see it that helps.
