Red Oak for Roof Spars
Postby Noah_and_Tina » Tue Jul 13, 2010 3:01 pm
Howdy all,
My wife and I are building our first teardrop following the Kuffel Creek plans. We've hit a little of a snag as of this past weekend. We're to the point of installing the roof spars and I can't get the ash or fir called for without taking a weekday off of work to go to a proper hardwood store. I can get red oak at the local home depot and/or lowes. Would the red oak make a suitable replacement for the other materials?
Thanks,
Noah
Noah_and_Tina
Postby aggie79 » Tue Jul 13, 2010 3:12 pm
Red oak will certainly be strong and will hold fasteners. You may want to consider poplar. It is slightly less expensive and is located next to red oak at the BORG (big orange retail giant) and the blue version of the BORG.
Postby caseydog » Tue Jul 13, 2010 3:18 pm
I used poplar for mine. It's easier to work with and cheaper than the red oak -- and it's right next to the red oak at Home Depot.
BTW, even though the poplar is softer than the oak, I still pre-drilled anywhere I used screws.
CD
My build journal is HERE
caseydog
Images: 515
Postby mikeschn » Tue Jul 13, 2010 4:15 pm
Red oak is an overkill.
Pine is fine! Hmmm... I gotta remember that next time I need a new signature line.
But really, I've build all my teardrops with pine spars. I just make sure there are no large knots in the spars, and no knots in the end where I put the screws into the endgrain.
Postby planovet » Tue Jul 13, 2010 4:20 pm
I also used pine for mine. (that rhymes too :lol: )
Red oak is overkill and more expensive.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Steve_Cox » Tue Jul 13, 2010 4:30 pm
I used yellow pine for roof spars,
Steve_Cox
Images: 196
Postby kennyrayandersen » Tue Jul 13, 2010 5:56 pm
Just stay away from the balsa...
Wht oak is my fave for structural apps but I'm with everyone else on this one -- pine be fine (and everything for there is fair.
An interesting note -- spruce is used a lot in aircraft construction due to strength per weight, but fir isn't far behind -- you can get that at the big box as well :thumbsup:
kennyrayandersen
Images: 38
Postby dh » Tue Jul 13, 2010 6:00 pm
Good luck finding straiht 1"x2" pine at the BORG. I bought a 12' piece of 2"x12" and had them cut two pieces 62" long out of it, the spars will be ripped out of these.
Straight(er) 1"x2" poplar should be available at the BORG as well.
Edit:
After thinking about this, I can see why red oak might be your choice, at my local box stores, most of the red oak is really straight.
dh
Postby mikeschn » Tue Jul 13, 2010 6:11 pm
Good point DH...
I rip all my spars from 2x10 or 2x12s.
Postby planovet » Tue Jul 13, 2010 6:33 pm
dh wrote:After thinking about this, I can see why red oak might be your choice, at my local box stores, most of the red oak is really straight.
Not always. I used red oak for my cabinets and I had a heck of a time finding really straight 1x2 and 1x3 red oak at the BORG. I would go through an entire stack to just find a few boards that were perfectly straight. Of course, YMMV.
ImageMark (& Cindi)
planovet
The Cat Man
Postby afreegreek » Tue Jul 13, 2010 7:21 pm
oak (red or white) is way too expensive unless you're going to leave it show.. poplar is notoriously unstable and will warp. it rots very quickly too.. your best bet is to buy some 2x spf (spruce- pine- fir) and rip your pieces out of that like others have suggested. that way you can get clear straight pieces with no knots.. another option is LVL.. laminated veneer lumber.. it's like plywood but all the grain is in one direction.. it's fantastic stuff.. it is made for load bearing applications (beams/joists/rafters etc) so the glue line is good and it will not warp or twist..
afreegreek
Postby afreegreek » Tue Jul 13, 2010 7:24 pm
you won't find it anywhere.. unless you are very lucky.. that goes for all woods really.. if you need straight and flat it's called jointer/planer..
afreegreek
Postby kennyrayandersen » Tue Jul 13, 2010 7:24 pm
mikeschn wrote:Good point DH...
That’s why I was suggesting fir – it comes in bigger pieces to whack off what you need (2X10, 2X12) which is 1 ½ thick so you can get 1½ X 1 inch stringers, which I think would be fine.
kennyrayandersen
Images: 38
Postby mikeschn » Tue Jul 13, 2010 7:38 pm
I have also used 1x10s in a a pinch, and ripped it 1 1/2" wide. As long as there are no big knots... so you end up with 3/4 x 1 1/2.
Postby ssrjim » Tue Jul 13, 2010 9:57 pm
I used furring strips except where the galley hinge is going to attach. Red oak for that.
93079
ssrjim
