Page 1 of 1
Floor Undercoating (Goo) Question
PostPosted: Tue Jul 13, 2010 8:11 pm
by J.Heyboer
I picked this up at homedepot, but after reading some of your posts I'm not sure if this is the right stuff, have any of you used this before?
John
PostPosted: Tue Jul 13, 2010 8:56 pm
by Miriam C.
Waterproof is the goal and this will work. It probably cost more than the tar stuff. Henry's is about $7 a gallon and works too. Almost anything that sticks and is water proof works.
PostPosted: Wed Jul 14, 2010 3:34 am
by dh
I'm sure it would work, but I found the Henreys realy user friendly. Low oder, easy clean up...
PostPosted: Thu Jul 15, 2010 11:12 am
by J.Heyboer
Thanks Miriam and DH,
I will give it try.
PostPosted: Sun Aug 01, 2010 7:39 pm
by Nosty
I may be too late to help you, but if I'm not, don't get the Henry's 501.
I made that mistake and am currently covered with it, smelling like the quart of mineral spirits it took to get it off of everything. I coated the underside of my floors Thursday and fitted them on the frame today. It felt rubbery until I got it on the frame. It's the dentu-grip of the roofing materials world! It took a block of wood and a sledge hammer to align the pieces and, when I applied any finger pressure, it came off on my hands.
I'm hoping the adhesion issue will be a positive further down the road, but, in the meantime, I've got a lot of touch up painting to do.
I can only pray that this is the worst mistake I'm going to make throughout this build.
Good luck, J.
Brian
