lindstrand wrote:I am just about ready to build my door and I am concerned about warping. I was thinking making it with 2x2 spruce and 1/8" plywood like I made my walls. I have a fairly large door 28x30 so I think overtime it will warp and cause sealing issues. I am trying to think of the best and cheapest way to make a door. Couple thoughts I have is run tensioned cables corner to corner but this interferes with my window. Fiberglass over the plywood pricey and I don't know how much resistance to bending that would add. Use aluminum instead of wood for studs and thats pricey and I can't weld aluminum. Laminate plywood together for a solid door but that would be heavy.
Anyway enough thinking out loud any comments or experiances (good or bad) would help
I have the same concern as you. It seems the same issues plague most builders. There are several, but the door warpage is a major one.
Here's my thought:
I Built my wall periameter with 1/8" laminations and it is really stiff and strong.
So, I ripped some 1 X 2 lumber into 1/4 x 3/4" strips and glued it back together with Titebond 3.
This was an experiment to see the difference between solid wood and the same wood cut into strips and glued back together.
I layed the 1X2x3' solid wood piece over the edge of a bench and pushed each end to see how much it would bend. I was fairly easy to bend.
I did the same thing with the laminated lumber. It was much more difficult to deflect this board.
I don't know if the laminations will help prevent warping, but they clearly stiffen the board. Maybe I could add some thin strip of hard wood, fiberglass or carbon fiber in the laminations to further stiffen these inner doors frames.
This method needs more thought.......Engineers please chime in.
Larry C
