Twin Wall Polycarbonate teardrop ? (Aquarium)
I was wondering if it would be possible to build a very light TD out of Twin Wall Polycarbonate sheets.
This stuff is readealy available, as it's commonly used in for sunroom / greenhouses and not expensive.
http://www.greenhouses-etc.net/glazing/twinwall.htm
http://www.sunporch.com/Content.aspx?pageid=DIRoofGlazing#TDIRGStrong
Positives:
- It can't rot (plastic)
- They make most UV resistant (since it's used outdoor)
- It's lightweight, yet quite sturdy /impact resistant (~0.3# / sqft)
- It's a decent insulator on it's own (~R2)
- Readily available and not too expensive.
- It's somewhat flexible (2 to 3 ft radius)
- It's see through - good for the windows
Negatives:
- "Aquarium" teardrop : It's see through !
- Obviously would need to be painted - not sure what paint could "stick" to that ?
- Only "fairly" flexible, not tight curves.
- I'm thinking it could get brittel under some thermal conditions, although specs says it's not
- Bonding: what kind of "glue" could be used ?
Anybody tried using that material or why it would be a bad idea ?
Positives:
Negatives:
