recycled plastic in leu of ply wood?
Postby eddie6775 » Fri Jul 23, 2010 9:32 pm
Hi everyone, I wass trying to find a good source of siding when I stumbled across this link. The makers claim it's lite weight, durable and uv resistant.
It might be a good matrail to replace ALL the plywood! I wonder.....
http://www.stop-painting.com/bt-sheetplastic.html
:twisted:
eddie6775
Postby caseydog » Fri Jul 23, 2010 9:38 pm
Hmmmmm, seems like an interesting material. I built with 3/4 birch, and 120 pounds seems pretty heavy on that recycled plastic, but on the plus side, water is not an issue -- no delaminating.
Thanks for the food for thought. :thumbsup:
CD
My build journal is HERE
caseydog
Images: 515
Postby eddie6775 » Fri Jul 23, 2010 9:44 pm
hey...nice trailer!..I'm designing a standie rite now, and the single biggest expence is the ply. I'm saving up now but dang....I'm thinking about that recycled stuff as a siding though. from what I've read here the frp needs paint to protect it. AND my local h.d. wants like $35 per sheet...so it's worth looking any way.
eddie6775
Plastic expansion
Postby eamarquardt » Fri Jul 23, 2010 10:08 pm
Not sure what you're looking at as far as what type of plastic it is but here is a recent string that might be relevant:
http://tnttt.com/viewto ... highlight=
Gus
eamarquardt
Images: 150
Postby doug hodder » Fri Jul 23, 2010 10:50 pm
Might be an idea to find out what the expansion and contraction #'s are with it in temp. extremes if plastic only is your path. A lot of movement will make it difficult to make a "torsion" box for strength. Having worked in the sign industry for 15 years...plastic sheet goods can do a lot of wild things in the heat/cold and typically don't have a lot of rigidity to them...Just my opinion. Doug
Postby eddie6775 » Sat Jul 24, 2010 7:35 am
hmmm... I had'nt thought of the problems with expantion and contraction yet. Good call! I'll have to investigate.
eddie6775
Postby kennyrayandersen » Sat Jul 24, 2010 9:48 am
also many plastics aren't very UV stable and go to crap in the sun.
kennyrayandersen
Images: 38
Postby Elmosaurus » Sat Jul 24, 2010 9:50 am
Polyethylene is generally a semi flexible plastic. It's used in the construction of everything from milk cartons to kayaks.
Even with wall thicknesses of up to 1/4", I've had kayaks where you could put dents in the material. Yes, the dent pops right back out, but it's far from a 'rigid' surface.
Worse yet, bonding Polyethylene is very difficult. Basically, when you get a crack or gouge in a kayak, you have to 'weld' it back together using highly focused heat and additional poly sticks. I'm not even sure high grade silicone sealant/adhesives will stick to it. I've never tried using construction contact adhesive like Liquid Nails, but my guess is it wouldn't hold; the moment the material flexed, the adhesion would crack and release.
Since the majority of our 'torsion box' effect comes from a solid bond on all perimeter seams, I'm not sure you could get the same level of rigidity out of the torsion box since you'd, at best, only be able to fasten screws into your framing ever few inches. And even then, without a way to properly seal the screw holes and window/door/vent openings, water intrusion is probably inevitable.
E.
Elmosaurus
Images: 71
