Has anyone built a tear or trailer using Structoglas?
Postby DANL » Sat Jun 26, 2004 9:08 pm
Has anyone tried this material for the shell of a teardrop. Might work best for walls and would probably have to laminate a nice skin to the inside. I'd be interested to hear how it went. Saw this at Menard's today. FRP laminated to 3/8 inch waferboard but I see by their site that it also comes on plywood or fluted poly.
http://www.kemlite.com/structoglas/str_products.cfm
Dan Jones
The tiny trailer in the avatar is designed to carry our recumbents and sometimes sleep in. We LOVE having a kitchen in the woods and a place for most of our gear.
Dan Jones http://sunsetlanding.com/teardrop/teardrop_intro.html
DANL
Postby Green Horn » Sat Jun 26, 2004 11:01 pm
I have a pop-up camper i have redone the ceiling in it ,It had like a cardboard backed board in the ceiling that started coming apart on me so i removed it and glued the kemlite to the foam that was under it.I used a matching molding to put over the seams and I have had great luck out of it. Easy to clean and very flexable .Was kinda costly If i remember correctly it was aroung 30.00 a sheet .It has been in a year now with no prob. to speak of.I used heavy duty Liquid Nail to glue it on to the foam which was already glued to the camper top..
Hope this Helps...
John In Bama with about 100% humidity and 95 degrees
Green Horn
Re: Has anyone built a tear or trailer using Structoglas?
Postby BufordT » Sun Jun 27, 2004 5:40 am
DANL wrote:Has anyone tried this material for the shell of a teardrop. Might work best for walls and would probably have to laminate a nice skin to the inside. I'd be interested to hear how it went. Saw this at Menard's today. FRP laminated to 3/8 inch waferboard but I see by their site that it also comes on plywood or fluted poly.
Dan Jones
Dan,
The pics to your left is my mini-hopper. I covered the roof, sides, front and back with the stuff. Got it at home depot for 26.00 a sheet. I used 3 different types of glues on it and found that the best was liquid nail for FRP. Worked the best and didn't cause any floating. I painted the stuff because it will not hold up to the sun's rays. Used kylon paint for plastic. Worked pretty good but it would be better if you used auto paint.
It's been out in the sun almost a year with no problems and I'll use it on any tear I build. Does have some draw backs. Only comes in 4x8, 4x10 and 4x12 sheets. If your tear or tiny trailer is larger than 4ft wide you would have to use something else or have a cover run over the joints.
Bufordt :twisted:
"RUSH" The Man, The Legend, The Way Of Life.
BufordT
2nd Teardrop Club
Images: 23
FRP Paint
Postby CPASPARKS » Sun Nov 27, 2005 10:32 pm
What type of paint would you think is the very best for painting FRP. Should any type of primer be applied first?
Kevin
CPASPARKS
Images: 7
Re: FRP Paint
Postby Steve_Cox » Sun Nov 27, 2005 11:09 pm
CPASPARKS wrote:What type of paint would you think is the very best for painting FRP. Should any type of primer be applied first?
The very best? Awlgrip
Primer? not just any type. Awlgrip primer.
But for a homebuilt teardrop, it's not worth the money that Awlgrip costs.
JMMFO
Hello CPASPARKS,
Welcome to the forum.... But I'll leave the rest of the welcome to the guys that do it best. You pulled up a pretty good thread from the past. There are a lot more about FRP and UV ETC
Steve_Cox
Images: 196
Postby madjack » Mon Nov 28, 2005 3:24 am
Welcome up there CPA, glad you decided to post...I am sure some of our very knowledgeable paint experts(yeah right) will be along with several suitable answers...some of them may even agree ;)
Re: FRP Paint
Postby BufordT » Mon Nov 28, 2005 5:46 am
What you are supposed to do is wash the FRP with TSP and water. Once you have it clean and dry your supposed to prime it with a good Auto primer and then paint it with a good auto paint.
I just used Kylon for plastics and it holds up pretty well.
I do have some scratches in the paint now and need to repaint but a can of plastic paint will take care of that.
Bufordt :twisted:
BufordT
2nd Teardrop Club
Images: 23
Postby larryl » Mon Nov 28, 2005 8:10 am
We used FRP on the ceiling and interior of hatch. It was great to work with as a material. I needed to paint the inside of the hatch and used a latex enamel paint. Preped with tsp. Easy to paint and looks real good.
Larry
larryl
Images: 22
Replies to painting FRP
Postby CPASPARKS » Mon Nov 28, 2005 9:29 am
Thanks gentlemen for all the good information.
I am hoping that a good coat of paint will prevent the uv light deterioration warnings that have been posted.
Now I just need to decide what color.
Kevin 8)
Kevin
CPASPARKS
Images: 7
Postby Walt Burville » Wed Mar 08, 2006 3:20 am
Ok BufordT, it's been a couple of years now. Is the HD frp still working out ok? I'm concerned about the thermal expansion factor being different from the wood it is adhered to. And the UV problem which you fixed by painting.
What's your evaluation after 2 years?
Walt B
Dan Jones
Dan,
Bufordt :twisted:
Walt Burville
Postby BufordT » Wed Mar 08, 2006 3:54 am
Walt,
As I don't have the tear here I can't say for sure. I will be checking it out at the end of April and I'll let you all know sometime in May.
Bufordt :twisted:
BufordT
2nd Teardrop Club
Images: 23
Re: FRP Paint
Postby DestinDave » Wed Mar 08, 2006 9:13 am
Yep... or Imron... It's a bit easier to apply than Awlgrip but again you have to use Imron (Dupont) primer... and it's priced about like Awlgrip... pretty expensive for a small one-time job.
Reality? What a concept!
Building "The Salty Tear" - a photo log of the project.
http://www.bluezenphoto.com/p979644357
DestinDave
